Tremendous Value
KBS Klean Qt: $12.95 RustBlast Qt: $17.95 RustSeal Qt: $41.95 KBS Top Coater Qt: $47.95 Thinner 8oz: $8.95 Brushes: $2.40 Nitrile Gloves: $.50
Total: $132.65 Only: $107.95 You Save: $24.70!
This complete kit takes our popular Frame Coater Kit to the next level. In addition to the complete KBS 3-Step System, this kit includes a Quart of KBS Top Coater for a permanent final finish which withstands dulling and fading caused by prolonged sunlight exposure.
Enough to cover 50 sq.ft! (2 Coats of RustSeal, 1-2 Coats of KBS Top Coater)
RustSeal Directions
KBS Top Coater Directions
RustSeal Technical Data
RustSeal How-To's
How To AvoidCommon RustSeal Mistakes
RustSeal - Which Color?
5.0
**NEW & IMPROVED** KBS Klean is a concentrated, water-based, biodegradable formula that is an excellent alternative to flammable solvents and hazardous chemicals. KBS Klean prepares your paint job with a clean surface. Try some today and see why customers say ...it's not really clean until it's KBS Klean'd!
KBS Top Coater is a superior coating formulated to be brushed, rolled or sprayed offering maximum coverage and professional looking results. KBS Top Coater is an ideal top coat paint for RustSeal when the area will be consistently exposed to sunlight. KBS Top Coater is a very high solids paint that does not run or sag, and gives at least twice the coverage of conventional paints.
