1. Home
Flame Torched Copper Coated with DiamondFinish Clear
DiamondFinish Clear on Fishing Lure
“Flame painted copper is done with a torch. NO paint. We use the DiamondFinish Clear to seal the copper and keep the colors permanent.” -Randy A from Scottsdale, AZ
DiamondFinish Clear is a crazy tough Clear Coat that can be applied Direct To Metal (ferrous and non-ferrous) or over other coatings.
DiamondFinish Clear is a water clear high gloss clear coat that remains permanently flexible and will perform in the toughest environments without yellowing, cracking or peeling.
DiamondFinish Clear can be applied directly to a cured Automotive basecoat, Standard solid color paints, and Single Part or Two-Part paints. It can also be applied to Non-Ferrous metals including Aluminum, Alloys, Brass, Chrome and Copper.
Read More
Fishing Lure Dipped in DiamondFinish Clear
DiamondFinish Clear is used by crank bait and fishing lure makers all over the world. Because DiamondFinish Clear is a moisture cured urethane, DiamondFinish Clear performs extremely well in marine environments.
Fishing Lures and Crank Baits can be dipped in DiamondFinish Clear for a non-porous clear finish that will withstand the elements including being submerged in water.
Read More
C40 Crew Cab Frame Coated with RustSeal
Frame Paint for C40 Crew Cab
The KBS 3-Step Rust Prevention System was used to coat the frame of a C40 Crew Cab. RustSeal chemically bonds to bare metal to form a permanent, moisture resistant finish that is flexible yet won't crack, chip, or peel. Because RustSeal is moisture-cured, this superior coating is made even stronger by continued exposure to moisture. RustSeal is the ideal choice for all rusty car and truck frames.
Read More
RustSeal Used for Rust Prevention on Coil Springs
RustSeal - Alternator Paint
One of the best attributes of RustSeal is its durability and flexibility. Because of this durability and flexibility, RustSeal is the ideal coating for stopping rust on coil springs and leaf springs.
Read More
