Cavity Coater is a one-step, super-penetrating corrosion inhibiting coating (CIC) for long term protection on all metal surfaces.
Cavity Coater provides a self healing film which renders over 4000+ hrs salt spray protection (meaning Insane Rust Protection) ...over 4 times the protection of conventional cavity waxes.
Use Cavity Coater with a KBS Cavity Wand to give long lasting protection for those hard to reach enclosed cavities such as rocker panels, boxed frames, inside doors & fenders, deck lids, tailgates...and more.
Automotive: Boxed frames • Rocker panels • Inside doors • Inside car & trailer frame rails • Windshield cowls • trunk lids • Hoods • Inside A-Posts • Inside B-Posts • Inside front & rear fenders & Inside tailgates • Back sides of bumpers • Weld seams (Wicks into welds & seams) • Insulating between unlike metal surfaces • Use wherever a typical cavity wax would be used.
Anti-Seize/Anti-Corrosion: Nuts, bolts & screws • Shafts • Pipe fittings • Gaskets • Press fit assemblies • Valve assemblies • Taps & drills • Pump mountings • Packing glands • Chain drives • Metal fittings • Machinery
Cavity Coater Directions
4.7
Exceptional Nitrile Gloves with an Aggressive Tread Grip! Red Lightning gloves offer excellent barrier protection and offer serious protection from your work environment while keeping your most important tools, your hands, in top condition for maximum productivity.
Everything you need to get started and try out our complete KBS system stopping rust from the inside out! A full 1/2 pint of RustSeal will cover an approx. 12 sq. ft. area with 2 coats and the Cavity Coater and Wand will seal up to 125 sq. ft. Experience the quality & durability for yourself. Our complete system in one package!
