Includes everything you need (Prep and Paint) to clear coat up to 100 sq. ft. with single coat coverage (brush, spray, or roll application).
Contains Quart of KBS Klean which is a concentrated, water-based, biodegradable formula industrial strength cleaner and degreaser. KBS Klean does not leave residues behind like solvent based cleaners making it ideal for clear coats.
Contains a Quart of DiamondFinish Clear which is an incredibly tough clear coat.
Contains 8oz of KBS #1 Thinner which is used for thinning and clean up.
DiamondFinish Clear is a water clear high gloss clear coat that remains permanently flexible and is able to perform in the toughest environments without yellowing, cracking, or peeling.
DiamondFinish Clear is insanely tough, hard, and abrasion resistant like no other clear coat on the market.
DiamondFinish Clear can be applied with a brush without leaving any brush marks.
