Got an area largerthan 12 sq. ft.? Go HERE to order the size of DiamondFinish Clearthat you need.
Includes everything you need (Prep and Paint) to clear coat up to 12 sq. ft.
Contains 8oz of KBS Klean which is a concentrated, water-based, biodegradable formula industrial strength cleaner and degreaser. KBS Klean does not leave residues behind like solvent based cleaners.
Contains 4oz of DiamondFinish Clear which is an incredibly tough Direct To Metal Clear Coat.
DiamondFinish Clear is a water clear high gloss clear coat that remains permanently flexible and is able to perform in the toughest environments without yellowing, cracking or peeling.
DiamondFinish Clear is insanely tough and hard like no other clear coat on the market.
DiamondFinish Clear can be applied with a brush without leaving any brush marks. The brushes are included in this convenient kit!
Theoretical coverage at one mil (25 µm) is 12 sq.ft. per 4oz. Recommended thickness of two mils (50 µm) would require two full coats. Three coats recommended for marine applications. Material losses during mixing and application will vary and must be taken into consideration. Expect up to 50% less coverage on bare wood, rough or sandblasted surfaces.
DiamondFinish Clear Directions
5.0
Exceptional Nitrile Gloves with an Aggressive Tread Grip! Red Lightning gloves offer excellent barrier protection and offer serious protection from your work environment while keeping your most important tools, your hands, in top condition for maximum productivity.
Quality brushes at a disposable price. Made with natural bristles for superior paint pick up and a smooth uniform finish.
**NEW & IMPROVED** KBS Klean is a concentrated, water-based, biodegradable formula that is an excellent alternative to flammable solvents and hazardous chemicals. KBS Klean prepares your paint job with a clean surface. Try some today and see why customers say ...it's not really clean until it's KBS Klean'd!
KBS Top Coater is a superior coating formulated to be brushed, rolled or sprayed offering maximum coverage and professional looking results. KBS Top Coater is an ideal top coat paint for RustSeal when the area will be consistently exposed to sunlight. KBS Top Coater is a very high solids paint that does not run or sag, and gives at least twice the coverage of conventional paints.
