Ever wanted to change the color of a flexible surface like plastic? Looking for a FAST drying and easy-to-apply flexible surface primer that allows you to quickly topcoat the surface? We have exactly what you need ... FUSION FPP!
KBS Fusion FPP is an excellent primer for flexible plastic, metal, wood, urethane, carbon fiber, and fiberglass.
KBS Fusion FPP features a fast dry time that allows you to increase your film thickness quickly.
KBS Fusion FPP coats fast and easy providing a tight bond for superior paint adhesion and is ideal for hard-to-paint surfaces.
KBS Fusion FPP is flexible, can be block sanded, and provides an excellent base for any number of topcoats.
Satisfaction guaranteed!
5.0
BlackTop is a permanent, moisture-cured, single stage, UV stable coating. BlackTop is a high-performance protective coating specifically formulated to withstand dulling and fading caused by prolonged sunlight exposure. BlackTop is primarily used for topcoating surfaces previously sealed with RustSeal or any other paint/primer application, but BlackTop also works well as a DTM bare metal coating.
DiamondFinish Clear Aerosol is tough Clear Coat that can be conveniently applied Direct To Ferrous Metals or over other coatings. DiamondFinish Clear Aerosol is a water clear aerosol clear coat that utilizes a professional grade acrylic resin system for supreme clarity and adhesion. DiamondFinish Clear Aerosol does not yellow, crack or peel.
