The perfect solution for cloudy headlight lenses. This kit includes everything you need to restore 4 or more headlight lenses which drastically increases the visibility of fogged, yellowed, cloudy, or hazy dull looking headlights and drastically improves their performance. Easy-to-follow detailed instructions included.
DiamondFinish Clear is insanely tough and hard, perfect for your headlights.
DiamondFinish Clear can be applied with a brush without leaving any brush marks. The brushes (and a scuff pad) are included in this convenient kit!
The Headlight Restore Kit should allow coverage of 4 or more average size headlight lenses.
4.7
This great 3-Step cost savings kit is designed to clean, prep, and repair your motorcycles, generators, lawn mowers, tractors, snowmobiles, or other small tanks up to 5 gallons. Detailed instructions included. Satisfaction guaranteed!
This great 3-Step cost savings kit designed for the repair of larger sized motorcycles, generators, lawn mowers, tractors, snowmobiles, or other tanks up to 12 gallons. Detailed instructions included. Satisfaction guaranteed!
NuMetal Epoxy Putty is a easy-to-use, two part putty you simply mix and mold like clay no complicated weighing or measuring required. Select BLACK, TAN, WHITE or GREY.
