KBS 2K DTM Build Primer Surfacer will get the vehicles out the door quickly.
KBS 2K DTM Urethane Build Primer features maximum holdout and minimal sand-scratch swelling.
KBS 2K DTM Build Primer dries fast and builds quickly.
KBS 2K DTM Build Primer is trusted by professionals all over the USA!
Metal • Galvanized • Aluminum • Fiberglass / SMC • Body Filler • OEM Primers / Finishes • Polyester • Putties • Etching Primers • Lacquers • Enamels • Urethanes
*All substrates must be prepared according to the TDS/Directions
5.0
BlackTop is a single stage, moisture-cured, and UV stable coating. BlackTop is a high-performance protective coating specifically formulated to withstand dulling and fading caused by prolonged sunlight exposure. BlackTop is primarily used for topcoating surfaces previously sealed with RustSeal or any other paint/primer application, but BlackTop also excels as a direct to bare metal coating, no primer required.
DiamondFinish Clear Aerosol is tough Clear Coat that can be conveniently applied Direct To Ferrous Metals or over other coatings. DiamondFinish Clear Aerosol is a water clear aerosol clear coat that utilizes a professional grade acrylic resin system for supreme clarity and adhesion. DiamondFinish Clear Aerosol does not yellow, crack or peel.
