KBS Bed Liner is a tough and flexible thick black protective coating designed to protect against corrosion andabrasion.
KBS Bed Liner is crazy durable withstanding impacts and improving traction.
KBS Bed Liner features excellent adhesion and extends the life of your vehicle.
Cars • Motorcycles • Wheels • Commercial Vehicles • Snow Plows • Fleet and Municipal Vehicles • Tractors • Agricultural Equipment • Construction Machinery • Trains
Gallon of KBS Bed Liner should coat up to 250 sq. ft.
KBS Bed Liner Directions
5.0
KBS Bed Renu is a tough and flexible thick black protective coating designed to touch up areas where your bedliner has worn away or needs “Renu’d”. KBS Bed Renu protects against corrosion & abrasion while withstanding impacts & improving traction. KBS Bed Renu features fast cure & excellent adhesion also extending the life of your vehicle.
**NEW & IMPROVED** KBS Klean is a concentrated, water-based, biodegradable formula that is an excellent alternative to flammable solvents and hazardous chemicals. KBS Klean prepares your paint job with a clean surface. Try some today and see why customers say ...it's not really clean until it's KBS Klean'd!
