KBS Bed Renu is a tough and flexible thick black protective coating designed to touch up areas where your bedliner has worn away or needs “Renu’d”.
KBS Bed Renu protects against corrosion and abrasion while withstanding impacts and improving traction.
KBS Bed Renu features fast cure and excellent adhesion also extending the life of your vehicle.
Cars • Motorcycles • Wheels • Commercial Vehicles • Snow Plows • Fleet and Municipal Vehicles • Tractors • Agricultural Equipment • Construction Machinery • Trains
15oz can of KBS Bed Renu should coat up to 30 sq. ft.
KBS Bed Renu Directions
5.0
