KBS Klean is a concentrated, water-based, biodegradable cleaner that is an powerful alternative to flammable solvents and hazardous chemicals for preparing your paint job with a clean surface.
KBS Klean is Step #1 in the KBS 3-Step Rust Prevention System and the KBS 3-Step Tank Sealing System.
KBS Klean is a powerful cleaner that deeply penetrates and removes stubborn soil from most surfaces without leaving harmful residues or emitting noxious fumes.
KBS Klean is perfect for the home, garage, or plant to effectively remove dirt, grime, oils, lubricants, grease, waxes, scum, algae, road film, and other contaminants.
KBS Klean is the ideal cleaner when prepping for a clear coat because KBS Klean does not leave a residue leaving you with a haze-free finish.
KBS Klean may be used in pressure washing equipment to produce the rapid penetration of many layers of accumulated build up. Cleaning projects have never been easier! Satisfaction guaranteed!
4.8
RustBlast is a powerful rust remover, zinc phosphate pre-primer, and metal etch. RustBlast effectively dissolves rust, corrosion, metal oxides, and tarnish from most metal surfaces. RustBlast is ideal for removing rust from chrome surfaces.
