A Superior 2K Urethane Clear Coat
KBS MAXX Clear is a superior performance, two-component, low VOC, low HAPs polyurethane clear coat specifically designed for the automotive, agricultural, fleet refinishing, marine, architects, and heavy industrial equipment markets.
KBS MAXX Clear offers excellent gloss retention as well as superior impact resistance, while providing fast drying characteristics.
KBS MAXX Clear is an excellent coating for the OEM marketplace looking to provide an automotive quality look and finish.
Cars • Motorcycles • Wheels • Bicycles • Commercial Vehicles• Snow Plows • Fleet and Municipal Vehicles • Tractors • Agricultural Equipment • Construction Machinery • Trains • Boats & Yachts • Personal Watercraft • Woodwork • Tools • Doors • Aerospace
High Gloss ... 90-95% measured at 60 degrees Satin ... 45-55% measured at 60 degrees Flat ... 5-15% measured at 60 degrees
Theoretical coverage at 2 mils DFT (which is a single coat) is 450 sq.ft. per gallon. Material losses during mixing and application will vary and must be taken into consideration. Expect up to 50% less coverage on bare wood, rough or sandblasted surfaces.
Quart ... 110 sq. ft.Gallon ... 450 sq. ft.5 Gallons ... 2250 sq. ft.
4.9
KBS Paint Mixing Cups are clear, disposable, flexible, graduated mixing cups. KBS Paint Mixing Cups are value priced, money and time saving mixing cups that are great for mixing and measuring KBS MAXX, RustSeal, DiamondFinish Clear, and all other KBS Coatings Paints and other 2K paints and 1K paints.
DiamondFinish Clear Aerosol is a tough Clear Coat that can be conveniently applied Direct To Ferrous Metals and Aluminum or over other coatings. DiamondFinish Clear Aerosol is a water clear aerosol clear coat that utilizes a professional grade acrylic resin system for supreme clarity and adhesion. DiamondFinish Clear Aerosol does not yellow, crack or peel.
