High Performance, Brush, Roll or Spray Application, Ultra Durable, High Solids, Low VOC, Low HAPS, 2K Topcoat
KBS MAXX is a superior performance, two-component, low VOC, low HAPs polyurethane topcoat. Specifically designed for the automotive, agricultural, fleet refinishing, marine, and heavy industrial equipment markets. Application is easy as KBS MAXX is designed to be brushed, rolled or sprayed!
KBS MAXX offers excellent gloss and color retention as well as superior impact resistance, while providing fast drying characteristics. An excellent coating for the OEM marketplace looking to provide an automotive quality look and finish in a single stage, two-component system.
Cars • Motorcycles • Wheels • Bicycles • Commercial Vehicles• Snow Plows • Fleet and Municipal Vehicles • Tractors • Agricultural Equipment • Construction Machinery • Trains • Boats & Yachts • Personal Watercraft • Woodwork • Tools • Doors • Aerospace
Theoretical coverage at one mil (25 µm) is 450 sq.ft. per gallon. Material losses during mixing and application will vary and must be taken into consideration. Expect up to 50% less coverage on bare wood, rough or sandblasted surfaces.
Quart: 110 sq. ft. Gallon: 450 sq. ft.
NOTE: If you want to see an exact color, please request a color sample HERE.
KBS MAXXDirections
4.9
This incredible all-purpose self-etching-primer is ideal for promoting adhesion between multiple surface coatings (including applications of topcoats or primers over cured RustSeal) in addition to priming bare metals such as steel, brass, aluminum, and most hard plastics.
KBS Top Coater is a superior coating formulated to be brushed, rolled or sprayed offering maximum coverage and professional looking results. KBS Top Coater is an ideal top coat paint for RustSeal when the area will be consistently exposed to sunlight. KBS Top Coater is a very high solids paint that does not run or sag, and gives at least twice the coverage of conventional paints.
