KBS Paint Saver is a proven paint preserver that allows user-friendly long term storing of leftover paints in the original can.
KBS Paint Saver keeps paints, coatings, and clear coats from skinning over in the can which saves you money by allowing you to use the entire can of paint.
KBS Paint Saver is designed to come out gently so as not to splatter the paint inside the can!
KBS Paint Saver is environmentally safe, allows for storage of paints in their original cans, and is very easy to use.
One Can of KBS Paint Saver Usually saves up to 75 cans of paint.
Simply hold paint can lid closely above the can and spray KBS Paint Saver towards the side of the paint can to avoid splashing. Spray KBS Paint Saver 2 seconds for quarts or less and 4 seconds for gallons. Close can lid immediately. KBS Paint Saver prevents oxygen and moisture damage that can happen in paint cans and extends storage times of paints, coatings and clear coats.
5.0
KBS Top Coater is a superior coating formulated to be brushed, rolled or sprayed offering maximum coverage and professional looking results. KBS Top Coater is an ideal top coat paint for RustSeal when the area will be consistently exposed to sunlight. KBS Top Coater is a very high solids paint that does not run or sag, and gives at least twice the coverage of conventional paints.
