Flexible Paint Spouts eliminate messy drips and keep grooves clean for resealing cans.
4.8
DiamondFinish Clear 1K Aerosol is a tough Clear Coat that can be conveniently applied Direct To Ferrous Metals and Aluminum or over other coatings. DiamondFinish Clear 1K Aerosol is a water clear aerosol clear coat that utilizes a professional grade acrylic resin system for supreme clarity and adhesion. DiamondFinish Clear 1K Aerosol does not yellow, crack or peel.
KBS Top Coater is a superior coating formulated to be brushed, rolled, or sprayed offering maximum coverage and professional looking results. KBS Top Coater is a direct to metal exterior grade coating that adheres permanently to steel and aluminum surfaces. KBS Top Coater is a very high solids paint that does not run or sag and gives at least twice the coverage of conventional paints.
