KBS Premium Body Filler is designed specifically for light filling and finishing.
KBS Premium Body Filler features a smooth self-leveling formula that facilitates excellent spreading, reducing sanding time and eliminating the need for finishing glaze.
KBS Premium Body Filler is formulated for faster working and is clog free, tack free and pinhole free. Allows for getting to priming and painting quickly.
KBS Premium Body Filler gives you superior sanding performance making the product ideal to reduce time and labor.
KBS Premium Body Filler is trusted by professionals all over the USA!
5.0
DiamondFinish Clear 1K Aerosol is a tough Clear Coat that can be conveniently applied Direct To Ferrous Metals and Aluminum or over other coatings. DiamondFinish Clear 1K Aerosol is a water clear aerosol clear coat that utilizes a professional grade acrylic resin system for supreme clarity and adhesion. DiamondFinish Clear 1K Aerosol does not yellow, crack or peel.
KBS Top Coater is a superior coating formulated to be brushed, rolled, or sprayed offering maximum coverage and professional looking results. KBS Top Coater is a direct to metal exterior grade coating that adheres permanently to steel and aluminum surfaces. KBS Top Coater is a very high solids paint that does not run or sag and gives at least twice the coverage of conventional paints.
