KBS Premium Body Filler is designed specifically for light filling and finishing.
KBS Premium Body Filler features a smooth self-leveling formula that facilitates excellent spreading, reducing sanding time and eliminating the need for finishing glaze.
KBS Premium Body Filler is formulated for faster working and is clog free, tack free and pinhole free.
KBS Premium Body Filler gives you superior sanding performance making the product ideal to reduce time and labor.
KBS Premium Body Filler is trusted by professionals all over the USA!
5.0
