KBS Rust Converter easily converts a rusty surface into a black, inert primed surface that is ready for paint and compatible with most topcoats and also protects against future rust.
While the most permanent solution for rust prevention is the KBS 3-Step System of KBS Klean, RustBlast and RustSeal, KBS Rust Converter can be used when you are unable to use the KBS 3-Step System.
Cars • Motorcycles • Wheels • Commercial Vehicles • Snow Plows • Fleet and Municipal Vehicles • Tractors • Agricultural Equipment • Construction Machinery • Trains • Tools • Doors
12oz aerosol can of KBS Rust Converter should coat up to 20 sq. ft.
5.0
RustBlast is a powerful rust remover, zinc phosphate pre-primer, and metal etch. RustBlast effectively dissolves rust, corrosion, metal oxides, and tarnishing from most metal surfaces. Ideal for removing rust from chrome surfaces.
**NEW & IMPROVED** KBS Klean is a concentrated, water-based, biodegradable formula that is an excellent alternative to flammable solvents and hazardous chemicals. KBS Klean prepares your paint job with a clean surface. Try some today and see why customers say ...it's not really clean until it's KBS Klean'd!
The Frame Coater Kit is our quart size 3-Step System Kit that includes enough products to Klean, Blast & Seal a full-size car or truck frame, or any 50 sq. ft. area with 2 coats of paint coverage. You get Top Quality Protection at a tremendous value! Detailed instructions included.
Black Lighting Gloves are the toughest and most comfortable disposable black nitrile gloves you'll ever use! The 5.5 PH technology found in Black Lighting Gloves helps to control perspiration while providing a natural skin feel. Black Lightning Gloves are highly chemical resistant, and they wear like iron.
