The KBS Tank Sealer System contains everything you need to prep correctly and seal your tank.
Gold Standard Fuel Tank Sealer is a superior, single-component, ready-to-use fuel tank sealer.
This all-inclusive kit contains our KBS Klean (a water-based, heavy-duty, cleaner/degreaser) and KBS RustBlast (a powerful rust remover/metal etch) to obtain a permanently sealed, rust-free fuel tank. These KBS prep products are formulated to leave a zinc phosphate film and an ideal surface profile for permanent adhesion of the Gold Standard Tank Sealer.
"I tried this product myself ... WORKED GREAT!!!!!"
Dave Stewart, Product Specialist for JP Cycles
Steel, Aluminum & Fiberglass Fuel Tanks • Oil Tanks • Utility Tanks • Diesel Tanks • Non-potable Water Tanks
Our Customers Say It Best...
Tank Sealer TDS/Directions
Tank Sealer Tech Data
3-Step Tank Sealing System
How To AvoidCommon Tank Sealer Mistakes
Tank Sealer How-To's
Tank Sealer Chemical Resistance
Learn how to seal up a Motorcycle Gas Tank with the KBS Cycle Tank Sealer Kit which gives you everything you need to seal a tank of up to 5 gallons.
Covers cleaning the tank with KBS Klean and etching the tank with RustBlast.
4.9
This great 3-Step cost savings kit is designed to clean, prep, and repair your motorcycles, generators, lawn mowers, tractors, snowmobiles, or other small tanks up to 5 gallons. Detailed instructions included. Satisfaction guaranteed!
Our "PLUS" Kit contains everything found in our regular Cycle Tank Sealer Kit, "PLUS" a quart of KBS Strip to quickly remove any old failing sealers previously used to seal your tank.
This great 3-Step cost savings kit designed for the repair of larger sized motorcycles, generators, lawn mowers, tractors, snowmobiles, or other tanks up to 12 gallons. Detailed instructions included. Satisfaction guaranteed!
Our "PLUS" Kit contains everything found in our Large Cycle Tank Sealer Kit, "PLUS" a quart of KBS Strip to quickly remove any old failing sealers previously used to seal your tank.
The Auto Fuel Tank Sealer Kit contains everything you need to clean, prep & permanently seal up to 25 gallon tank. Detailed instructions included. Satisfaction guaranteed!
A money-saving 3-Step repair kit which includes enough products to clean, prep & permanently seal up a 25-50 gallon tank. Detailed instructions included. Satisfaction guaranteed!
