Maximum Coverage and Professional Looking Results!
KBS Top Coater is a superior spray paint formulated for maximum coverage and professional looking results. KBS Top Coater is an ideal top coat paint for RustSeal when the area will be consistently exposed to sunlight.
KBS Top Coater is a very high solids paint does not run or sag, and gives at least twice the coverage of conventional spray paints. KBS Top Coater can be applied to bare metal, but for ultimate performance, apply KBS Top Coater over RustSeal.
NOTE: If an exact color is critical to your application, please request a free painted out color sample HERE. The colors shown can vary from device to device and monitor to monitor so it is best practice to get the actual painted out color sample before placing your order when an exact color is critical for your application.
Cars • Motorcycles • Wheels • Bicycles • Commercial Vehicles• Snow Plows • Fleet and Municipal Vehicles • Tractors • Agricultural Equipment • Construction Machinery • Trains • Boats & Yachts • Personal Watercraft • Woodwork • Tools • Doors • Aerospace
16oz can of KBS Top Coater should coat up to 38 sq. ft. with 1 coat coverage.
12oz can of KBS Top Coater should coat up to 30 sq. ft. with 1 coat coverage.
Material losses during mixing and application will vary and must be taken into consideration. Expect up to 50% less coverage on bare wood, rough or sandblasted surfaces.
KBS Top Coater Directions
5.0
This incredible all-purpose self-etching-primer is ideal for promoting adhesion between multiple surface coatings (including applications of topcoats or primers over cured RustSeal) in addition to priming bare metals such as steel, brass, aluminum, and most hard plastics.
KBS UnderCoat is a superior rubberized paintable undercoating that provides protection in wheel wells, gas tanks, frames, and floor pans. KBS UnderCoat produces a very tough, yet flexible film with excellent adhesion, and helps prevent road salt from eating away at your car's metal and fiberglass.
