Designed to cure KBS Patch when sunlight is not feasible or available.
Order KBS Patch HERE!
The KBS UV Light is a lightweight, handheld UV flashlight containing 51 Ultraviolet LED bulbs for greater area coverage.
The KBS UV Light includes batteries and features an aircraft aluminum alloy body and is water resistant. The included batteries will run the flashlight for 20 hours.
LED: 51
Bulb Type: LED 390 to 395nm
Bulb Life: 10,000 hours
Body Material: Aluminum with O-rings for water resistance
Batteries Required: 3 x AA alkaline batteries (included)
Battery Life: Approximately 20 hours on 3 AA batteries
Switch Type: Push On/Off Button
Weight: 10 oz. (285g) including batteries
Head Diameter: 57mm
Body Diameter: 36mm
Length: 147mm
5.0
