1 Reviews +Write a Review
This complete kit takes our popular Large Frame Coater Kit to the next level. In addition to the complete KBS 3-Step System, this kit includes a Quart of KBS Top Coater for a permanent final finish which withstands dulling and fading caused by prolonged sunlight exposure.
Questions? Ask Here.
Part #: 576
Price Each: $161.95
Retail Price:$169.95
Your Savings:$8.00(5%)
19 Review(s)
112 Review(s)
419 Review(s)
80 Review(s)
330 Review(s)
DiamondFinish Clear Aerosol is tough Clear Coat that can be conveniently applied Direct To Ferrous Metals or over other coatings. DiamondFinish Clear Aerosol is a water clear aerosol clear coat that utilizes a professional grade acrylic resin system for supreme clarity and adhesion. DiamondFinish Clear Aerosol does not yellow, crack or peel.
26 Review(s)
10 Review(s)
Recently Viewed Items
