The all-inclusive KBS Large System Sampler Kit contains everything you need to clean, prep, and apply two coats of RustSeal on up to a 25 square foot area.
RustSeal is a total rust inhibitor and rust preventive coating.
RustSeal features incredible brushed flow out characteristics. Your project will look like it has been powdercoated even when it was brushed!
RustSeal chemically bonds to rusted steel to form a rock-hard, non-porous coating that won't crack chip, or peel. It works by isolating metal from moisture. Without moisture present, steel can't rust.
RustSeal is a non-porous, flexible coating that is incredibly tough and extremely resistant to abrasion and impact.
RustSeal is highly surface tolerant and capable of adhering to almost any prepared surface.
Our Large System Sampler Kit preps and seals 25 sq. ft. with two coats.
4.9
Quality natural bristle brushes at a disposable price. Made with natural bristles for superior paint pick up and a smooth uniform finish.
The Frame Coater Kit is our complete quart size kit that includes enough products to Klean, Blast, and Seal a full-size car or truck frame, or any 50 sq. ft. area with 2 coats of paint coverage and rust protection. You get Top Rated Rust Protection at a tremendous value! Detailed instructions included give you professional results.
The All-In-One Chassis Kit takes our popular Frame Coater Kit to the next level. In addition to the complete KBS 3-Step System, this all-inclusive kit includes a pint of BlackTop topcoat for a permanent durable final finish which withstands dulling and fading caused by prolonged sunlight exposure.
The Trunk and Floorpan Repair Kit is a restoration kit that will save you money versus the cost of replacement. Restore your floor pan, trunk, or pickup truck bed back to new and never deal with rust again! Easy-to-follow detailed instructions included.
