The all-inclusive KBS Large System Sampler Kit contains everything you need to clean, prep, & apply two coats of RustSeal on up to a 25 square foot area. Don't get short changed, our kit includes 16 ounces of our RustSeal coating.
RustSeal is a total rust inhibitor and rust preventive.
RustSeal has the consistency of paint and it has very good spreadability.
RustSeal chemically bonds to rusted steel to form a rock-hard, non-porous coating that won't crack chip, or peel. It works by isolating metal from moisture. Without moisture present, steel can't rust.
RustSeal is a non-porous, flexible coating that is incredibly tough and extremely resistant to abrasion and impact.
RustSeal is highly surface tolerant and capable of adhering to almost any prepared surface.
Our Large System Sampler Kit seals 25 sq. ft. with two coats.
RustSeal Directions
RustSeal Flow Chart
RustSeal Technical Data
How To Avoid Common RustSeal Mistakes
RustSeal How-To's
RustSeal - Which Color?
RustSeal Chemical Resistance Guide
4.9
The Frame Coater Kit is our quart size 3-Step System Kit that includes enough products to Klean, Blast & Seal a full-size car or truck frame, or any 50 sq. ft. area with 2 coats of paint coverage. You get Top Quality Protection at a tremendous value! Detailed instructions included.
The Trunk and Floorpan Repair Kit is a restoration kit that will save you money versus the cost of replacement. Restore your floor pan, trunk, or pickup truck bed back to new and never deal with rust again! Easy-to-follow detailed instructions included.
