Make sure to only use KBS #1 Thinner for the thinning of RustSeal and our other Rust Preventive Paints. Regular solvents may contain moisture that can adversely affect the performance of our coatings.
Also, keep some KBS #1 Thinner on hand for your immediate clean up needs.
4.9
Exceptional Nitrile Gloves with an Aggressive Tread Grip! Red Lightning gloves offer excellent barrier protection and offer serious protection from your work environment while keeping your most important tools, your hands, in top condition for maximum productivity.
KBS Top Coater is a superior coating formulated to be brushed, rolled or sprayed offering maximum coverage and professional looking results. KBS Top Coater is an ideal top coat paint for RustSeal when the area will be consistently exposed to sunlight. KBS Top Coater is a very high solids paint that does not run or sag, and gives at least twice the coverage of conventional paints.
