KBS Paint Mixing Cups are clear, disposable, flexible, graduated mixing cups. KBS Paint Mixing Cups are value priced, money and time saving mixing cups that are great for mixing and measuring KBS MAXX, RustSeal, DiamondFinish Clear, and all other KBS Coatings Paints and other 2K paints and 1K paints.
KBS Paint Mixing Cups are made of clear plastic which allows perfect visibility into your container. The KBS Paint Mixing Cups have several accurate graduated mixing and measuring scales and ratios clearly printed on the inside of the paint mixing cup which include milliliters (ml) and mixing ratios from 2 to 1, 3 to 1, 4 to 1, 5 to 1, 6 to 1, and 7 to 1 plus scaled marked percentages which are easily used when thinning paints for spraying.
The KBS Paint Mixing Cups are durable and flexible mixing cups made of plastic that's solvent resistant to most paint chemicals, but the KBS Paint Mixing Cups are not made to be used for paint storage. KBS Paint Mixing Cups make measuring stress-free and mess-free!
5.0
KBS MAXX is a superior performance, two-component (2K), low VOC, low HAPs, permanently UV stable polyurethane topcoat that can be applied by brush, roller or sprayer. KBS MAXX is specifically designed for the indoor and outdoor applications including automotive, agricultural, fleet refinishing, marine, and heavy industrial equipment markets.
Downstream moisture will ruin your spray job. Stop failure with our direct in-line filter at the gun.
These simple to use Flexible Paint Spouts eliminate messy drips and keep grooves clean for resealing cans. One size fits all gallon, quart, and pint cans, and are reusable too! Order enough for all your painting needs.
