KBS 2K DTM Build Primer and Surfacer features exceptional high build and direct-to-metal properties. KBS 2K DTM Build Primer is light grey and offers exceptionally soft sanding, both wet or dry, within short dry times. KBS 2K DTM Build Primer provides maximum gloss holdout, eliminates sand scratch swelling, and promotes excellent adhesion. Base and Activator are included!
2 Review(s)
KBS Premium Body Filler is polyester reinforced and designed for light filling and finishing. KBS Premium Body Filler features a smooth formula that facilitates excellent spreading, reducing sanding time and eliminating the need for finishing glaze. KBS Premium Body Filler is lightweight and fast drying.
2 Review(s)
NuMetal Epoxy Putty is a easy-to-use, two part putty you simply mix and mold like clay no complicated weighing or measuring required. Select BLACK, TAN, WHITE or GREY.
67 Review(s)
KBS Patch is an easy-to-use, UV/sunlight activated repair patch. The fiberglass-reinforced polyester patch creates long-lasting repairs. Perfect for making watertight, durable repairs on engine parts, decking, fenders, gas cans, drain pipes, water tanks, PVC pipes, plastics, Plexiglas, fiberglass, metal, wood, concrete and more.
6 Review(s)
The KBS UV Light is a lightweight, handheld UV flashlight containing 51 Ultraviolet LED bulbs for greater area coverage.
1 Review(s)
