Tired of seeing those rusted rotors through custom wheels?
KBS Coatings has the answer: the KBS Rotor Restoration Kit. This exciting new kit includes everything needed to clean, prep, prime and coat those rusted eyesores and bring them back to a showroom appearance.
The Rotor Restoration Kit includes KBS Klean, RustBlast, XTC Primer and XTC to guarantee that you get the job done right and the rust does not come back!
The Rotor Restoraion Kit has enough product to prep, prime, and coat 4 or more standard car rotors.
Rotor Restoration Kit Directions
5.0
Motor Coater is easy to apply, offers superb coverage and yields a self-leveling professional looking finish brushed or sprayed. These engine enamels provide deep, rich pigmented colors for excellent coverage. Your engine will be a show stopper at this DIY price!
XTC is a high temperature/heat resistant coating formulated specifically to protect metal surfaces operating at temperatures from 500° F to 1500° F. With proper preparation, XTC provides outstanding adhesion, film integrity, weathering, and thermal shock-resistance throughout this entire temperature range, and is guaranteed not to burn off! Available in 10 great colors.
XTC Silicone Zinc Primer prevents corrosion of metal surfaces exposed to high heat, high humidity, condensation and salt air. It functions much like galvanizing as it locks itself to bare metal surfaces leaving a perfect primed surface for top coating. XTC Silicone Zinc Primer can be used alone as a finish paint. It withstands temps in excess of 1200F (648C).
