Easy-to-use spray or brush application. Apply RustBlast full strength to a clean surface keeping it wet for at least 30 minutes or more and watch rust, corrosion, metal oxides, and tarnishing vanish before your eyes!
RustBlast will gently etch the surface and leave a zinc phosphate coating to ensure a strong bond with any paint.
Satisfaction guaranteed!
RustBlastDirections
RustBlast How-To's
KBS ApplicationFlow Chart
5.0
The Frame Coater Kit is our complete quart size kit that includes enough products to Klean, Blast, and Seal a full-size car or truck frame, or any 50 sq. ft. area with 2 coats of paint coverage and rust protection. You get Top Rated Rust Protection at a tremendous value! Detailed instructions included give you professional results.
