5.0
Cavity Coater is the Perfect Solution for hard-to-reach areas that are prone to rusting! Cavity Coater is a single step, super-penetrating corrosion inhibiting coating (CIC) designed for long term protection on all metal surfaces. KBS Cavity Coater provides a self-healing film which provides insane rust protection on hard to reach areas.
KBS UnderCoat is a superior rubberized paintable undercoating that provides protection in wheel wells, gas tanks, frames, and floor pans. KBS UnderCoat produces a very tough, yet flexible film with excellent adhesion, and helps prevent road salt from eating away at your car's metal and fiberglass.
This VOC friendly waterbased undercoating provides protection in wheel wells, gas tanks, frames, and floor pans. KBS UnderCoat produces a very tough, yet flexible film with excellent adhesion, and helps prevent road salt from eating away at your car's metal and fiberglass.
This superior undercoating provides protection in wheel wells, gas tanks, frames, and floor pans. KBS UnderCoat produces a very tough, yet flexible film with excellent adhesion, and helps prevent road salt from eating away at your car's metal and fiberglass.
