How to Stop and Prevent Rust on Steel UTV Skid Plates
Skid plates are some of the hardest-working parts on a UTV. Every time you roll over rocks, logs, stumps, ruts, and trail debris, the skid plates take the pounding so your UTV’s engine, driveline, chassis, suspension, and belly pan don’t. They’re essential armor—and for many riders, nothing beats steel skid plates for impact resistance and long-term durability.
But unlike UHMW or aluminum skid plates, steel skid plates can rust. And once a skid plate’s coating is scratched or gouged, rust can move fast. Whether you’re riding in wet conditions, rocky terrain, or areas treated with winter road salt, that constant exposure can turn a strong steel plate into a weak, corroded one.
This guide explains UTV skid plate rust prevention, coating UTV skid plates effectively, and the best DIY method for steel skid plate rust protection using KBS products. You’ll learn how to stop existing rust, apply durable coatings, and protect your skid plates for years of off-road use.
What Are UTV Skid Plates Made of?
Most OEM and aftermarket UTV skid plates come in one of three materials:
Steel
- Most impact-resistant
- Best puncture resistance
- Typically, the most affordable
- Heavier than aluminum or UHMW
- Susceptible to rust when coatings are damaged
Aluminum
- Lighter than steel
- Doesn’t rust
- Can dent more easily
- Corrosion is usually minimal unless exposed to saltwater or road salt
UHMW (Ultra-High Molecular Weight Plastic)
- Doesn’t rust or corrode
- Extremely slick surface—slides well over obstacles
- Flexes rather than dents
- Not as stiff as steel
While aluminum and UHMW are attractive options, many riders prefer steel because it bends less, punctures less, and handles harsh impacts better. The downside? Rust is a constant threat.
Why Does Rust Form on Steel UTV Skid Plates?
Manufacturers finish steel skid plates with powder coat or other paints and coatings. They look great when new, but off-road use can chip, scratch, and gouge these finishes. Once bare metal is exposed to moisture, mud, oxygen, or salt, oxidation begins.
Because skid plates can stay wet and trap mud, they often rust faster than other parts of the UTV.
To solve this, you need a durable rustproof coating for UTV skid plates designed for extreme use—not just ordinary paint.
What Is the Best Coating for UTV Skid Plates and Why Use KBS Coatings?
For maximum durability and longevity, KBS provides a two-part DIY friendly coating system—KBS RustSeal followed by KBS Bed Liner or KBS Bed Renu
A permanent rust-preventive coating that seals steel off from moisture, oxygen, and corrosives. A thick, flexible, UV-stable protective coating that absorbs impacts and abrasion. Together, these coatings create: This system works on: KBS RustSeal is a 1K moisture-cured urethane formula engineered to stop rust permanently. It dries to a rock-hard but flexible finish that resists impacts and abrasion—perfect for steel UTV skid plates. KBS RustSeal forms the first layer of protection. To maximize durability, you finish by applying KBS Bed Liner over it. While KBS RustSeal handles the job of stopping and preventing rust, KBS Bed Liner (or optionally - KBS Bed Renu
Together, KBS RustSeal + KBS Bed Liner (or KBS Bed Renu
Surface prep is a highly important step. KBS RustSeal bonds strongest when prep is done correctly. Use one of the following: Your goal is to remove all loose coating, loose rust, and failing paint. KBS RustSeal needs a solid foundation for the strongest, most durable adhesion. If some coating is still firmly adhered: Scuff it with 320-grit sandpaper to give RustSeal a tooth to grip. Once loose rust and paint have been removed, and/or well adhered existing coatings have been scuffed, the surface must be completely cleaned with KBS Klean. This powerful degreaser and cleaner removes dirt, grease, and grime, without leaving adhesion-hindering residue. Before applying KBS RustSeal the metal needs to be treated with KBS RustBlast. Yes—unless the metal was sandblasted; KBS RustSeal can be directly applied to newly sandblasted metal surfaces that have been handled with gloved hands. No preparation other than blowing off loose dust is required. Once dry, you’re ready to apply KBS RustSeal. Once fully cured, the metal is sealed against rust and ready for the Bed Liner topcoat. Before application of KBS Bed Liner scuff the fully cured KBS RustSeal with 320 grit sandpaper for best adhesion of Bed Liner. This is your protective armor layer—perfect for off-road skid plate coating and long-term impact resistance. KBS Bed RenuKBS Bed Liner1. KBS RustSeal
2. KBS Bed Liner
3. KBS Bed Renu
Why Is KBS RustSeal Ideal for Steel Skid Plate Rust Protection?
KBS RustSeal benefits include:
Why Add KBS Bed Liner Over KBS RustSeal?
KBS Bed Liner is:
How Do You Prepare Steel UTV Skid Plates Before Coating?
Step 1: Remove Loose Rust, Paint, and Coating
How Do You Clean Skid Plates Before Applying KBS RustSeal?
Use KBS Klean as directed:
What’s the Next Step Before Applying RustSeal?
Why use KBS RustBlast?
Do You Need KBS RustBlast Before Applying RustSeal?
How Do You Apply KBS RustBlast Properly?
How Do You Apply KBS RustSeal to UTV Skid Plates?
How Do You Apply KBS Bed Liner for Maximum Durability?
KBS Bed Renu: How to Apply for Long-Lasting Results
- Prepare KBS RustSeal as described above
- Hold KBS Bed Renu
- Spray in smooth, overlapping passes, releasing the trigger at the end of each stroke
- For maximum durability, apply 5-6 thin coats, avoiding heavy passes
- Allow 1-2 hours cure time between coats depending on humidity levels
- Full cure is usually achieved within 48 hours
- Full instructions HERE
Can Bed Liner Be Repaired If Skid Plates Get Damaged?
Yes, if the KBS Bed Liner topcoat gets gouged, scraped, or torn during off-road riding, you can use KBS Bed Renu
Bed Renu:
- Bonds to the original Bed Liner
- Restores protection
- Matches the texture closely
- Helps maintain long-term rust prevention
This makes ongoing maintenance simple.
Conclusion: What’s the Best Way to Protect Steel UTV Skid Plates Long-Term?
The combination of KBS RustSeal + KBS Bed Liner or KBS Bed Renu
- UTV skid plate rust prevention
- High-impact wear resistance
- Long-term protection from salt, moisture, and corrosion
- Superior steel skid plate rust protection compared to standard paint or powder coat
Whether you’re installing brand-new steel skid plates or restoring used ones, this two-part system offers professional-grade protection that DIY’s can confidently achieve.
You’ll get:
- A skid plate that resists rust
- A coating that absorbs harsh off-road abuse
- Performance that lasts for seasons—not just months
If you want the best coating for UTV skid plates, this system delivers outstanding results, long-term durability, and a finish that holds up on rugged trails, rocky climbs, muddy creek crossings, and everything in between.
