The KBS Stop Rust Gallon Kit contains everything you need to clean, prep, & apply two coats of RustSeal on up to a 200 square foot area.
KBS Coatings’ 3-Step System of RustSeal (a rust preventive coatings), KBS Klean (an industrial strength water-based cleaner / degreaser) and KBS RustBlast (a powerful metal etch / rust remover) is the most effective rust and corrosion prevention system available today.
RustSeal chemically bonds to bare metal to form a permanent, moisture resistant finish that is flexible yet won't crack, chip, or peel. Because RustSeal is moisture-cured, this superior coating is made even stronger by continued exposure to moisture.
RustSeal is also highly resistant to some of the most aggressive chemicals such as acids, alkalis, salts, abrasive materials, fertilizers, coal dusts, solvents, oils, and other refined petroleum products.
5.0
Black Lighting Gloves are the toughest and most comfortable disposable black nitrile gloves you'll ever use! The 5.5 PH technology found in Black Lighting Gloves helps to control perspiration while providing a natural skin feel. Black Lightning Gloves are highly chemical resistant, and they wear like iron.
The All-In-One Chassis Kit takes our popular Frame Coater Kit to the next level. In addition to the complete KBS 3-Step System, this all-inclusive kit includes a pint of BlackTop topcoat for a permanent durable final finish which withstands dulling and fading caused by prolonged sunlight exposure.
