The KBS Stop Rust Quart Kit contains everything you need to clean, prep, & apply two coats of RustSeal on up to a 50 square foot area.
The KBS Stop Rust Quart Kit contains contains KBS Coatings’ 3-STEP SYSTEM of RustSeal (a rust preventive coatings), KBS Klean (an industrial strength water-based cleaner / degreaser) and RustBlast (a powerful rust remover / metal etch) is the most effective rust and corrosion prevention system available today.
RustSeal chemically bonds to bare metal to form a permanent, moisture resistant finish that is flexible yet won't crack, chip, or peel. Because RustSeal is moisture-cured. which features the latest in coating technology, RustSeal is made even stronger by continued exposure to moisture.
RustSeal is also highly resistant to some of the most aggressive chemicals such as acids, alkalis, salts, abrasive materials, fertilizers, coal dusts, solvents, oils, and other refined petroleum products.
*Click HERE for more information on which color of RustSeal you should use. NOTE: Some colors of RustSeal are only available in select sizes.
KBS Tip
Doing more than just your frame?Want to do the whole underside of your vehicle?
Check out the Large Stop Rust Quart Kit!
The Stop Rust Quart Kit should prep and coat 50 sq. ft. with two coats. Material losses during mixing and application will vary and must be taken into consideration. Please expect up to 50% less coverage on bare wood, rough, or sandblasted surfaces.
👉 How to Stop Rust and Prevent Rust
👉 RustSeal - Showing the Insane Durability and Flexibility of this Rust Preventive Paint
👉 Stacey David Video: Rust Prevention Products Used To Stop and Prevent Rust on Car Surfaces
👉 Video: Lawnmower Deck Rust Removal and Painting with RustSeal
👉 RustSeal Rust Prevention Formulation Keeps KBS Coatings as the Leader of the Pack
RustSeal Video - Extreme Durability and Flexibility
5.0
Quality natural bristle brushes at a disposable price. Made with natural bristles for superior paint pick up and a smooth uniform finish.
The Preval Sprayer Kit and Spray Gun is the perfect solution for applying coatings from KBS Coatings to small areas where control and quality of finish are important. The Preval Sprayer Kit is convenient and converts most paints into the ease of applying an aerosol paint.
The All-In-One Chassis Kit takes our popular Frame Coater Kit to the next level. In addition to the complete KBS 3-Step System, this all-inclusive kit includes a pint of BlackTop topcoat for a permanent durable final finish which withstands dulling and fading caused by prolonged sunlight exposure.
