Withstands 450°F Continuous Heat
✔ Made in USA
📦 Free Shipping on Orders $75+
Available in 41 Colors
The Complete Engine Prep & Coating System
Stop fighting peeling, flaking engine paint. The Motor Coater Kit gives you every product needed — in the right order — for a finish that holds up to heat, oil, and years of daily driving.
Prep Right. Coat Once. Done for Good.
The Motor Coater Kit is built around a proven sequence. Each step works with the next, so your finish bonds deeper and lasts longer than any rattle-can approach.
1
Degrease with KBS Klean
Mix KBS Klean with hot water and scrub away grease, oil, and grime. This concentrated, water-based cleaner leaves zero residue — so nothing stands between your metal and the coating.
2
Etch & Rust-Treat with RustBlast
Apply RustBlast to dissolve remaining rust, neutralize corrosion, and chemically etch the metal surface. No need to chase every rust spot — RustBlast handles it and creates the ideal bonding profile for Motor Coater.
3
Coat with Motor Coater Engine Enamel
Apply Motor Coater by brush, roller, or spray gun. Its self-leveling formula eliminates brush marks and delivers a smooth, professional finish. One full coat covers completely — a second coat can be applied within 30 minutes or after 7 days.
Engine Blocks & Heads
The most popular use. Motor Coater is formulated specifically for the heat cycles, oil drips, and under-hood environment your engine lives in every day.
Transmissions & Differentials
Match your trans and diff to your engine bay finish. Motor Coater bonds to cast iron and aluminum alike for a consistent, professional look under the hood.
Brake Calipers
Motor Coater's high-temp resistance and strong adhesion make it an ideal choice for calipers — whether you're going factory correct or adding a pop of custom color.
Alternators, Brackets & Accessories
Detail every inch of your engine bay. Motor Coater works on all metal components, giving your entire build a cohesive, show-ready appearance.
Other KBS Products for Your Truck Build
From frames and undercarriages to fuel tanks and headers, KBS has a coating for every part of your build that demands professional-grade protection.
KBS RustSeal — Permanent Rust Preventive Coating
The foundation of any serious truck build. RustSeal permanently stops rust on frames, floor pans, brackets, and body metal. It seals over existing rust and bonds directly to bare metal — no primer needed.
Shop RustSeal
KBS BlackTop — Chassis and Undercarriage Paint
Chassis & Undercarriage
UV-stable chassis paint built specifically for frames, undercarriages, and suspension components. BlackTop holds its deep black finish even after years of sun, road salt, and moisture exposure.
Shop BlackTop
KBS XTC Xtreme Temperature Coating — Up to 1500°F
Extreme Heat
XTC Xtreme Temp Coating
When your headers and exhaust see temperatures Motor Coater isn't rated for, reach for XTC. Formulated to withstand up to 1,500°F, it's the coating for headers, manifolds, and mufflers.
Shop XTC
KBS Gas Tank Sealer Kit — 3-Step Fuel Tank Restoration
Fuel System
Gas Tank Sealer Kit
Restore a rusty or leaking fuel tank without replacing it. The three-step Gas Tank Sealer Kit cleans, treats, and permanently seals steel and fiberglass tanks — compatible with all fuels including ethanol blends.
Shop Tank Sealer Kit
Motor Coater FAQ
New to KBS Motor Coater? Here are the answers to the questions we hear most from truck builders.
No primer is required when you use the KBS prep system. Clean the surface with KBS Klean and etch with RustBlast — RustBlast acts as a zinc phosphate pre-primer that etches the metal and creates an ideal bonding surface for Motor Coater. On heavily pitted or rust-prone surfaces, an optional base coat of KBS RustSeal can be applied first to smooth the surface and permanently stop any remaining rust before the finish coat goes on.
Aerosol engine paints use light-bodied formulas with minimal film build — they're convenient, but they rely entirely on surface prep the can can't provide. Motor Coater is a professional-grade enamel designed around a complete system: degrease with KBS Klean, etch and rust-treat with RustBlast, then apply Motor Coater. That sequence is why Motor Coater won't blister, flake, crack, or peel the way rattle-can paints eventually do, even on engines that see consistent heat, oil drips, and chemical exposure.
No — Motor Coater is fully air-cured under normal ambient conditions. Parts can be gently handled after 2–4 hours. Full hardness is achieved after 7 days. If you want to accelerate the cure, wait 12 hours after painting, then place the part in direct sunlight for one hour followed by one hour in the shade — repeat this heat cycle as needed. Once cured, no additional heat cycling on the engine is required.
Motor Coater is available in 41 rich, deep colors — including all the classic OEM engine colors (Chevy Orange, Ford Blue, Mopar Red, Cast Iron Gray, and many more), plus satin and gloss blacks, aluminum, and metallic options. Metallic colors can be brushed on by first applying the coat normally, then lightly brushing the surface in one direction after a few minutes to bring the metallic pigments to the surface.
KBS Coatings ships from Valparaiso, Indiana, typically within one business day of your order. Free shipping is available on all orders of $75 or more within the contiguous United States. Use code STREETTRUCKS at checkout for your exclusive 10% discount.
