Material
Spill, splash or incidental / occasional contact
Periodic contact (<1 hour per day)
Immersion, constant contact or condensation vapours
Acetic Acid 5%
3
3
3
Acetic Acid 10%
3
3
3
Acetone
3
3
3
Ammonium Hydroxide 1%
3
3
3
Ammonium Hydroxide 5%
3
3
3
Benzene
3
3
3
Biodiesel (B100)
3
3
3
Bleach
3
3
3
Brake Fluid
3
3
NR
Chromic Acid 20%
3
3
NR
Citric 10%
3
3
3
Coal Dust
3
3
3
Deionized Water
3
3
3
Detergent Solution Weak
3
3
3
Detergent Solution Strong
3
3
3
Diesel
3
3
3
Distilled Water
3
3
3
Ethylene Glycol (Antifreeze)
3
3
3
Ethanol
3
3
3
Ferric Chloride 2%
3
3
3
Ferric Sulfate 10%
3
3
3
Grape Juice
3
3
3
Heptane
3
3
3
Hexane
3
3
3
Hydraulic Fluid
3
3
3
Hydrochloric Acid 10%
3
3
3*
Hydrochloric Acid 20%
3
3
NR
Hydrogen Peroxide Solution 3%
3
3
3
Hydrogen Sulfade (sewer gas)
3
3
3
Kerosene
3
3
3
Lactic Acid 5%
3
3
3
Lactic Acid 10%
3
3
3
Methanol
3
3
3
Methylene Chloride
NR
NR
NR
Methyl-Ethyl Ketone
3
3
NR
Mineral Spirits
3
3
3
Nitric Acid 5%
3
3
3
Nitric Acid 10%
3
3
3*
Nitric Acid 30%
3
3
NR
Oil (Automotive)
3
3
3
Oil (Vegetable)
3
3
3
Oleic Acid
3
3
3
Petrol (Automotive Fuel)
3
3
3
Petrol  (Aviation Fuel)
3
3
3
Jet Fuel
3
3
3
Phenol Solution
3
3
3
Phosphoric Acid 10%
3
3
3
Phosphoric Acid 70%
3
3
NR
Potassium Hydroxide
3
3
NR
Salt Brine
3
3
3
Skydrol
3
3
3
Strong Soap Solution 4%
3
3
3
Sodium Chloride
3
3
3
Sodium Hydroxide 10%
3
3
3*
Sodium Hydroxide 50%
3
3*
NR
Sodium Hypochlorite 2%
3
3
3
Sulfuric Acid 10%
3
3
3*
Sulfuric Acid 25%
3
3*
NR
Sulfuric Acid 50%
3
3*
NR
Sulfuric Acid 95%
3
3*
NR
Toluene
3
3
3
Trichloroethane
3
3
3
Water (Distilled)
3
3
3
Xylene
3
3
3
3 = Suitable for general applications
3* = Generally suitable but some testing should be done prior to use
NR = Not Recommended
PLEASE NOTE: This Tank Sealer Chemical Resistance Guide is a GUIDE ONLY to the general chemical resistance of Gold Standard Tank Sealer and cannot be used as a bible for all applications and conditions without prior testing. All tested substrates were prepped according to the Tank Sealer TDS the Tank Sealer was 5 mil film thickness. Average temperature when applied was 70F.
Common variables to be aware of include temperature; direction of the heat; any localized heating (hot spots); chemical concentration levels; different preparation techniques; chemical layering; differing substrates and varying film thickness of applied Gold Standard Tank Sealer.
