Tank Sealer Kits - Everything You Need to Prep and Seal Your Tank
Video: Tank Sealer Overview
Gold Standard Fuel Tank Sealer is a superior, one part, ready-to-use fuel tank sealer that is specifically formulated to stop rust and corrosion.
When used in combination with KBS Klean and RustBlast, Tank Sealer will form a super-tough, fuel and alcohol blended fuels impervious coating, while simultaneously sealing small pinholes and weld seams. Tank Sealer may be used on steel, aluminum, and fiberglass tanks.
Applications for Tank Sealer Kits include fuel tanks, diesel tanks, biodiesel tanks, oil tanks, air compressor tanks, utility tanks, and non-potable water tanks. Tank Sealer is 100% impervious to modern day fuels, alcohol additives, and most solvents.
34 Review(s)
236 Review(s)
49 Review(s)
538 Review(s)
33 Review(s)
19 Review(s)
