1. Home
Prevent cracking, peeling, and rust on your suspension springs! Learn how to prep and paint coil & leaf springs using the KBS 3-Step System for a long-lasting, flexible finish. Read more→
Read More
Did you know you can use KBS RustSeal like Glyptal to seal and protect the internal surfaces of your engine? RustSeal prevents rust, improves oil drain-back, and keeps your engine cleaner for longer. Learn how to coat your engine like the pros in our latest guide. →
Read More
How to Paint Rusty Exhaust Headers So the Finish Won’t Crack, Flake, or Peel
This in-depth guide explains why header paint peels and shows how proper prep, high-temperature coatings, and correct heat curing deliver a durable, long-lasting finish that won’t crack, flake, or burn off under extreme heat. →
Read More
Thinking about painting your aluminum wheels black, but worried the finish won’t last? Learn how to achieve strong paint adhesion on aluminum wheels with long-term durability against heat, brake dust, and road debris using KBS MAXX.
Read More
What’s the Most Durable Way to Seal Wood Exposed to Heavy Use and Harsh Conditions?
Learn why RustSeal outperforms oil or water based polyurethane sealers and epoxy sealers on heavy-use wood and see how to apply it for maximum durability. Read the full step-by-step guide.
Read More
How Do You Stop and Prevent Rust on Steel UTV Skid Plates?
Protect your steel UTV skid plates from rust, impacts, and harsh off-road abuse. Learn how this simple DIY system using RustSeal, Bed Liner and Bed Renu deliver long-lasting, professional-grade results.
Read More
Protect your shed floor from moisture, rot, pests, and heavy wear with the right coating. This guide shows why sealing a wood shed floor matters, which products work best, and how to prep and coat the surface for long-lasting, DIY results.
Read More
Protect your dock from costly rust damage and corrosion with this step-by-step guide. Learn how to clean, prep, seal, and finish steel and aluminum docks using KBS Klean, RustBlast, RustSeal, and KBS MAXX for lasting durability and a professional finish.
Read More
A Proper Body Repair Method That Keeps Rust from Coming Back
Rust can destroy even your best body repairs from the inside out. In this guide we show you a proven method to stop rust from returning.
Read More
How to Stop and Prevent Rust on Your Boat Trailer: A Complete Guide
Rust not only makes your trailer look bad but can also compromise its structural integrity. This guide will show you how to stop existing rust and prevent future rust on your boat trailer using the KBS Coatings Ultimate Frame Coater Kit.
Read More
How Can I Stop Rust and Make My Old Steel Fence Look New?
Is rust and faded paint making your steel fence look tired? Addressing these issues now can improve its appearance and prevent costly future repairs. This guide shows how to stop rust using RustSeal or KBS Rust Converter, then finishing with BlackTop.
Read More
How to Spot Treat Undercar Rust Before Winter | Rust Converter & RustSeal Guide
Protect your vehicle’s underside before winter. Learn how to spot treat rust on frame rails, floor pans, and suspension parts using KBS Rust Converter and RustSeal. →
Read More
How To Properly Open a Paint Can Preventing a Stuck Lid and How To Preserve Paint In The Can
Over the years, one of the most useful tips we give to our customers is how to properly open a paint can so it be sealed correctly. In the video, we show you how to properly open and close a paint can from KBS Coatings.
Read More
How Do You Clear Coat Over Rust and Preserve the Patina Look?
Preserving the aged, weathered look of rusted metal is a growing trend in automotive restoration, industrial design, and artistic projects. To maintain that patina without letting corrosion worsen, applying a clear coat over rust is essential. In this article, we’ll explain what rust patina is, why it’s worth preserving, and how to effectively protect it using KBS Coatings DiamondFinish Clear and KBS MAXX Clear.
Read More
Do I Need to Use a Primer with High-Temperature Paint?
A common question that arises is: "Do I need to use a primer with high-temperature paint?" The answer primarily depends on exposure conditions. In many cases, using a high-temperature primer can enhance durability and corrosion resistance, ensuring a long-lasting finish. In this article we discuss when and how to use XTC and XTC Primer.
Read More
How to Prepare Metal for Painting Using KBS Klean and RustBlast for Superior Adhesion
Properly preparing metal surfaces for painting is essential to get the paint to bond and achieve a durable, professional-looking finish that doesn’t flake or peel. Here we will cover the steps to prepare metal for painting, with a focus on the use of KBS Klean and RustBlast.
Read More
How to Get Paint to Stick to Plastic
Painting plastic surfaces can be a daunting task, often resulting in poor adhesion if not done correctly. See how KBS Klean, KBS SEP Self-Etching Primer and KBS FPP Flexible Plastics primer are used to prepare plastic for excellent adhesion of top coats.
Read More
We always recommend using KBS Klean to clean a surface before coating or painting. We formulated KBS Klean as an alternative to solvent based cleaners and degreasers which notoriously leave a residue on the surface which can cause surface tension. KBS Klean rinses clean and does not leave a residue.
Read More
Clear Coat for Water-Based Paint and Coatings
DiamondFinish Clear is a clear coat that is incredible for protecting latex and as a clear coat for water-based paint and coatings of other types. This article describes all of the benefits for using DiamondFinish Clear to seal and protect surfaces painted with water-based coatings.
Read More
Snowplows receive a lot of abuse during a busy season and wear and tear can take their toll. Maintaining a snowplow is much less expensive than replacing it or making significant repairs. We describe in this article how to prep and coat a rusty snowplow.
Read More
How to Detail Your Engine and Engine Bay with KBS Klean
A clean engine bay looks great and makes a car or truck easier to maintain. This article describes how to use KBS Klean as part of this process to detail your engine making your job so much easier.
Read More
The Best Way to Paint Brake Rotors and Restore Brake Rotors
Brake rotors have a big impact on the appearance of wheels. This article describes how to easily restore your rusty brake rotors and how to prevent rust on brake rotors.
Read More
How to Achieve an Incredible Looking Finish When Applying A Moisture Cured Paint
Being patient and taking care to not apply coats too thickly and allowing sufficient dry time between coats allows moisture cured urethanes to cure correctly leaving a beautiful and durable finish. This article describes how to properly apply moisture cured urethanes.
Read More
Coatings That Are Tough, Durable and Hard While Also Being Extremely Flexible
We get an honest question asked all the time: “How can your coatings be hard and flexible? That does not make sense!”
When we started KBS Coatings, we utilized paint chemists that were on the forefront of coatings technology, and they helped us develop coatings that utilized innovative Cross-Linked Coatings Technology. Not only does this coatings technology (used in RustSeal, Tank Sealer, DiamondFinish Clear, KBS MAXX, KBS MAXX Clear, KBS Top Coater, Motor Coater) allow our coatings to adhere incredibly well to surfaces but this technology also allows our coatings to be insanely durable and hard while still being flexible enough to be applied to coil springs and leaf springs.
Gelcoat Clear Coat
A diagram that shows what our coatings do is really nice but most people want to see this coatings technology in action. We get that.
Here is a video showing the toughness and flexibility of DiamondFinish Clear.
Also, here is a video showing the toughness and flexibility of RustSeal.
If you have a coatings application where you need a hard and durable coating that is flexible and adheres well, we have plenty of options for you. Please be sure to get some today!
Read More
How To Properly Open a Can of Paint and Then Store The Can of Paint for Future Use
In the video below, we show you how to properly open and close a paint can from KBS Coatings. Because most of our paint is shipped at some point, there is a chance that the paint in the can might get between the can and the lid which can make getting the lid off more difficult than it might be with an ordinary latex paint. Latex paints do not provide nearly the adhesion that is provided with paints from KBS Coatings so that is why opening our paint cans is an essential critical first step.
In the video, we also show you how to use KBS Paint Saver. KBS Paint Saver is a proven paint preserver that allows user-friendly long-term storing of leftover paints in the original can. KBS Paint Saver keeps paints, coatings, and clear coats from skinning over in the can saving you money by allowing you to use the entire can of paint. KBS Paint Saver is environmentally safe, allows for storage of paints in their original cans, and is extremely easy to use.
At KBS Coatings, we want you to be able to make the most of your investment which is why we show you how to open and close the paint can and how to use KBS Paint Saver to preserve the paint in the can.
Read More
RustBlast is a Powerful Rust Remover - Keep Surface Wet
DiamondFinish Clear on Fishing Lure
Keep Surface Wet and Then Rinse With Water
This tip for RustBlast is a simple one but just as easily misunderstood. As a powerful rust remover and acid etch, RustBlast will only etch metal and dissolve rust while it remains damp. By letting RustBlast dry before reapplying you might allow an excessive amount of zinc phosphate to build up.
If RustBlast isn't rinsed off (RustBlast should always be rinsed at the end) this excess zinc phosphate can create a barrier that could keep RustSeal from adhering property.
By making sure that you both reapply RustBlast while wet, and rinse RustBlast off when done, you ensure that RustBlast will do the premium job that it's designed to do.
Read More
Seal Your Lawnmower Deck To Prevent Grass From Sticking
Remember Your Lawnmowers!
Pick a glossy finish like Gloss Black RustSeal for the slickest surface and watch the grass fall right off and not clog up your mower. Because the underside of most mower decks is coarse, we always apply at least 3 thin coats for this application.
Read More
Apply RustSeal In Thin Coats
APPLY RUSTSEAL IN THIN COATS
Remember that RustSeal should be applied in THIN coats. Applying too heavily, will cause running and/or sagging on vertical surfaces, and possible bubbling on horizontal surfaces. As RustSeal cures, it releases a small amount of carbon dioxide. If allowed to "puddle", the top of the RustSeal directly exposed to the ambient humidity in the air (the actual catalyst for RustSeal) will begin to "skin" over. This "skinning over" is much like that of chocolate pudding and blocks the release of the afore mentioned carbon dioxide causing bubbles. By applying thin coats, this film cures through and through all at once.
MORE TIPS & TRICKS
RustSeal Fix-It Guide: This guide helps you quickly identify the causes of and the recommended solutions for the most common issues that could occur for RustSeal.
Read More
Tip of the Month – Patience When Using Tank Sealer
PATIENCE IS A VIRTUE THAT WILL BE REWARDED...
Over the years, one of the BEST TIPS that we can give to people who are sealing a tank is to BE PATIENT. Proper prep and sealing IS NOT a lunch hour project. The KBS 3 Step System works perfectly if the Instructions are followed which includes:
  • Be Patient and allow the KBS Klean the time to thoroughly dissolve all the oily fuel residues before rinsing.
  • Be Patient and allow the RustBlast to soak and disintegrate the rust in your tank before rinsing.
  • Be Patient while waiting for the tank interior to dry completely as the tank can NEVER be too dry!
  • Be Patient and allow the tank to cool to room temperature before applying the sealer.
  • Be Patient when sloshing the sealer around to insure complete coverage.
  • Be Patient when draining any & all excess sealer from the tank.
  • Be Patient while waiting for the sealer to cure.
Click HERE for Detailed Tank Sealer Instructions.
Read More
