Maximum Coverage and Professional Looking Results!
KBS Top Coater is a superior single part coating formulated to be brushed, rolled or sprayed offering maximum coverage and professional looking results.
KBS Top Coater is an ideal top coat paint for RustSeal when the area will be consistently exposed to sunlight.
KBS Top Coater is a very high solids paint that does not run or sag, and gives at least twice the coverage of conventional 1K paints.
- Rock Hard Yet Flexible Coating
- Excellent Adhesion to Paints and Primers
- High Solids Formulation Provides Excellent Hiding Qualities
- Does Not Fade. 100% UV Stable!
- Does Not Run or Sag
- Twice The Coverage of Conventional Paints
- Chemical Resistant
- Fast Drying
- Excellent Durability
- High Temperature Resistance: Withstands Up To 300°F
Cars • Motorcycles • Wheels • Bicycles • Commercial Vehicles• Snow Plows • Fleet and Municipal Vehicles • Tractors • Agricultural Equipment • Construction Machinery • Trains • Boats & Yachts • Personal Watercraft • Woodwork • Tools • Doors • Aerospace
Note: As a general rule for most applications, 2 coats are usually ideal.
Quart of KBS Top Coater should coat up to 175 sq. ft. with 1 coat coverage and 90 sq. ft. with 2 coat coverage.
Gallon of KBS Top Coater should coat up to 700 sq. ft. with 1 coat coverage and 350 sq. ft. with 2 coat coverage.
Material losses during mixing and application will vary and must be taken into consideration. Expect up to 50% less coverage on bare wood, rough or sandblasted surfaces.
Looking for Black In Gloss, Satin, or Flat?
BlackTop is available in a Brush, Roll or Spray Formulation!
NOTE: If you want to see an exact color, please request a color sample HERE.
