Topcoats And Clearcoats
KBS MAXX is a superior performance, two-component (2K), low VOC, low HAPs, permanently UV stable polyurethane topcoat that can be applied by brush, roller or sprayer. KBS MAXX is specifically designed for the indoor and outdoor applications including automotive, agricultural, fleet refinishing, marine, and heavy industrial equipment markets.
KBS MAXX Clear is a superior 2K Urethane UV Stable Clear Coat that provides a long lasting and durable finish while keeping its beautiful finish for years.
The KBS Top Coater Aerosol Camo 4 Pack is a superior aerosol spray paint formulated for maximum coverage, insane durability and professional looking results. The Camo 4 Pack includes all 4 camo colors: Flat Black Camo, Green Camo, Desert Tan Camo and Brown Camo. KBS Top Coater is a very high solids paint does not run or sag, and gives at least twice the coverage of conventional spray paints.
KBS Bed Renu is a tough and flexible thick black protective coating designed to touch up areas where your bedliner has worn away or needs “Renu’d”. KBS Bed Renu protects against corrosion & abrasion while withstanding impacts & improving traction. KBS Bed Renu features fast cure & excellent adhesion also extending the life of your vehicle.
KBS Bed Liner is a tough and flexible thick black protective coating designed to protect against corrosion and abrasion while withstanding impacts & improving traction. KBS Bed Liner features excellent adhesion and extends the life of your vehicle.
KBS Top Coater is a superior aerosol spray paint formulated for maximum coverage and professional looking results. KBS Top Coater is an ideal top coat paint for RustSeal when the area will be consistently exposed to sunlight. KBS Top Coater is a very high solids paint does not run or sag, and gives at least twice the coverage of conventional spray paints.
DiamondFinish Clear is a crazy tough Clear Coat that can be applied Direct To Metal or over other coatings. DiamondFinish Clear is a water clear high gloss clear coat that remains permanently flexible and is able to perform in the toughest environments without yellowing, cracking or peeling. A quart of DiamondFinish Clear should cover 100 sq. ft. single coat coverage.
DiamondFinish Clear is a crazy tough Clear Coat that can be applied Direct To Metal or over other coatings. DiamondFinish Clear is a water clear high gloss clear coat that remains permanently flexible and is able to perform in the toughest environments without yellowing, cracking or peeling. A pint of DiamondFinish Clear should cover 50 sq. ft. single coat coverage.
DiamondFinish Clear is a crazy tough Clear Coat that can be applied Direct To Metal or over other coatings. DiamondFinish Clear is a water clear high gloss clear coat that remains permanently flexible and is able to perform in the toughest environments without yellowing, cracking or peeling. A gallon of DiamondFinish Clear should cover 400 sq. ft. single coat coverage.
