This ULTIMATE KIT takes the All-In-One Chassis Kit to the next level providing inside-out rust protection. In addition to the complete KBS 3-Step Rust Protection System, this ULTIMATE KIT includes a pint of BlackTop 1K UV stable topcoat for a permanent final finish which withstands dulling and fading caused by prolonged sunlight exposure AND ALSO includes Cavity Coater and Wand to seal up the inside of the frame and chassis.
RustSeal Video - Showing Extreme Durability and Flexibility
Cavity Coater Application Video
5.0
DiamondFinish Clear 1K Aerosol is a tough Clear Coat that can be conveniently applied Direct To Ferrous Metals and Aluminum or over other coatings. DiamondFinish Clear 1K Aerosol is a water clear aerosol clear coat that utilizes a professional grade acrylic resin system for supreme clarity and adhesion. DiamondFinish Clear 1K Aerosol does not yellow, crack or peel.
KBS Top Coater is a superior coating formulated to be brushed, rolled, or sprayed offering maximum coverage and professional looking results. KBS Top Coater is a direct to metal exterior grade coating that adheres permanently to steel and aluminum surfaces. KBS Top Coater is a very high solids paint that does not run or sag and gives at least twice the coverage of conventional paints.
