The Ultimate Frame Coater Kit contains everything you need to clean, prep, and apply two coats of RustSeal on up to a 50 square foot area.
The Ultimate Frame Coater Kit also contains Cavity Coater and Cavity Wand which is the Perfect Solution for hard to reach areas that are prone to rusting!
KBS Coatings’ 3-Step System of RustSeal (a rust preventive coatings), KBS Klean (an industrial strength water-based cleaner / degreaser) and KBS RustBlast (a powerful rust remover / metal etch) is the most effective rust and corrosion prevention system available today.
RustSeal is an incredible, single-component, ready-to-use, high solids content, rust preventive coating with exceptional sealing properties.
No other brand is tougher on rust! Using premium quality materials and advanced color formulations, this high tech performance coating is the present-day answer for 21st century rust protection.
RustSeal is the most permanent cost-effective solution for stopping rust and corrosion anyplace where it is a problem: home, automotive, industry, fleet, farm & more!
Unlike other corrosion treatments, RustSeal is an enhancement that lasts. Water and air are locked out, therefore oxidation, the precursor to rust, cannot take hold.
It’s technology that’s unbeatable! Satisfaction guaranteed!
