The Ultimate System Sampler Kit contains everything you need to clean, prep, & apply two coats of RustSeal on up to a 12.5 square foot area. Don't get short changed, our kit includes 8 ounces of our RustSeal coating...not just 4 ounces. Twice the surface coverage!
The Ultimate System Sampler Kit also contains Cavity Coater and Cavity Wand which is the Perfect Solution for hard to reach areas that are prone to rusting!
RustSeal is a paint-like substance. RustSeal acts as a total rust inhibitor and preventive.
It's consistency is approximately that of paint and it has very good spreadability. RustSeal chemically bonds to rusted steel to form a rock-hard, non-porous coating that won't crack chip, or peel. It works by isolating metal from moisture. Without moisture present, steel can't rust.
This non-porous, flexible coating is incredibly tough and extremely resistant to abrasion and impact. RustSeal is highly surface tolerant and capable of adhering to almost any prepared substrate.
Tremendous Value
KBS Klean 8oz: $6.95 RustBlast 8oz: $7.95 RustSeal 8oz: $18.95 Cavity Coater Aero: $24.95 Cavity Wand: $13.95 Brushes: $2.40 Nitrile Gloves: $.50
Total: $75.65 Only: $56.95 Your Savings: $18.70!
The Ultimate System Sampler Kit seals 12.5 sq. ft. with two coats of RustSeal.
RustSeal Directions
RustSeal Flow Chart
RustSeal Technical Data
How To AvoidCommon RustSeal Mistakes
RustSeal How-To's
RustSeal - Which Color?
Cavity Coater Directions
4.8
The Frame Coater Kit is our quart size 3-Step System Kit that includes enough products to Klean, Blast & Seal a full-size car or truck frame, or any 50 sq. ft. area with 2 coats of paint coverage. You get Top Quality Protection at a tremendous value! Detailed instructions included.
The Trunk and Floorpan Repair Kit is a restoration kit that will save you money versus the cost of replacement. Restore your floor pan, trunk, or pickup truck bed back to new and never deal with rust again! Easy-to-follow detailed instructions included.
