KBS UnderCoat - Solvent-Based Asphalt
7 Reviews +Write a Review
This superior undercoating provides protection in wheel wells, gas tanks, frames, and floor pans. KBS UnderCoat produces a very tough, yet flexible film with excellent adhesion, and helps prevent road salt from eating away at your car's metal and fiberglass.
Aerosol: $12.95  |  Aerosol Case (12): $139.95
Quart: $22.95  |  Gallon: $66.95  |  5 Gal Pail: $278.95
Questions? Find Answers Here!
Part #: 76
Price Each: $0.00
Ideal for Applying KBS UnderCoat and KBS Cavity Coater as well as other Corrosion Inhibitors, Cavity Waxes and Undercoatings.
3 Review(s)
19 Review(s)
112 Review(s)
419 Review(s)
80 Review(s)
10 Review(s)
Recently Viewed Items
