TIP: For the ultimate rust protection, follow the KBS 3-Step System and treat the bare metal areas with RustSeal before applying KBS UnderCoat. KBS UnderCoat will have excellent adhesion to cured RustSeal.
KBS UnderCoat provides protection in a Low VOC Formulation for wheel wells, gas tanks, frames, quarter panels, fenders, undercarriages, hoods, decks, and floor pans.
KBS UnderCoat produces a very tough, yet flexible film with excellent adhesion, and helps prevent road salt from eating away at your car's metal and fiberglass.
KBS UnderCoat offers excellent adhesion to metal or painted surfaces.
KBS UnderCoat provides economical paintable durability, plus moisture resistance & corrosion resistance, all in a matte black finish.
KBS UnderCoat also provides sound deadening by reducing road noise and vibration.
Note: Not for use on surfaces that will come in direct contact with heat or high temperatures such as mufflers or exhaust components.
