To achieve expert results, please take the time to carefully read and understand the following directions before you begin your restoration project. These directions are meant to be general guidelines only and do not cover every application or environmental situation. If you have remaining questions or concerns, please Contact Us for technical assistance.
DESCRIPTION:
XTC is a high temperature/heat resistant coating formulated specifically to protect metal surfaces operating at temperatures from 500°F to 1500°F. With proper preparation, XTC provides outstanding adhesion, film integrity, corrosion, weathering and thermal shock-resistance throughout this entire temperature range, and is guaranteed not to burn off!
RECOMMENDED USES:
Engines, Manifolds, Headers, Mufflers • Furnaces, Kilns, Ovens, Stoves • Compressors, Turbines • Stoves (wood, coal, pellet, gas, etc.) • Fireplace hoods, screens, & accessories
FEATURES:
Withstands continuous temperature of up to 1500°F (812°C) • Outstanding heat and weathering resistance • Will not peel, flake, or chalk • Long Lasting • Dries for handling in 15 minutes • Once heat cured, is resistant to scratching & marring
NOT RECOMMENDED FOR:
Parts that will be immersed • Direct contact with open flame • Cooking surfaces
SURFACE PREPARATION:
Steel surface to be primed must be dry and free from dirt, oils, rust, and other contaminants. Sandblasting is the ideal surface preparation as it leaves the ideal anchor pattern for paint adhesion. After sandblasting, use clean compressed air to blow off any residual blast media. Be sure to wear surgical-type gloves when handling to keep natural body oils off the prepared surface.
If not sandblasting, prepare surface by using wire wheel, wire brushing, or abrasive sanding using 60-80 grit paper. This method will provide a surface equivalent to that provided by sandblasting and allow the desired surface profile or anchor pattern.
Wash surface with KBS Klean at a 10:1 (Water/KBS Klean) ratio, rinse and let dry thoroughly to wash away residual oils. Allow surface to thoroughly dry before proceeding.
Mask off areas not to be coated & protect adjacent areas with drop cloth or newspapers.
For best results, apply when XTC and room temperatures are between 60-80° F.
MIXING:
Do not open containers until ready to use. Re-disperse any settled-out pigments by stirring. Use of a mechanical mixer (KBS Hurricane Paint Mixer or simliar mixing blade attached to drill) is highly recommended. Effective mixing includes repeatedly touching bottom of can and lifting to disperse any settled pigments and/or matting agents. Placing paint can upside down for a short time before opening and mixing will aid with proper mixing. Keep lid on container when not in use.
NOTE: XTC Primer and XTC are heavily pigmented, so it can take at least 5-10 minutes of mixing with the KBS Hurricane Paint Mixer to get XTC and XTC Primer into its homogenous state, ready for application.
COVERAGE:
Theoretical coverage at one mil (25 microns) is 360-400 sq.ft. per gallon. Recommended thickness of two mils (50 microns) would require two full coats. Material losses during mixing and application will vary and must be taken into consideration. Expect up to 30% less coverage on rough surfaces. Aerosol Can theoretically covers 10-15 sq. ft.
APPLICATION:
Ideal application temperatures of air and substrate to be coated are 50-82°F (15-28°C). XTC may be applied by conventional or HVLP spray, airless spray, brush or roller. Do not apply XTC in heavier films than specified since blistering may occur. As with all KBS Products, multiple very thin, covering coats is always the best practice.
For corrosion protection and rust protection, metal surfaces should always be primed with XTC Primer which is our silicone zinc rich high temperature and corrosion resistant primer (approx. 1.0 mils/25um DFT), then top-coated with one coat (1.0 mils/25um DFT) of the XTC color of your choice.
NOTE: XTC Primer is not required for adhesion, simply follow the surface preparation above and XTC will adhere incredly well direct to metal with no primer needed. XTC Primer provides rust protection and corrosion protection. Strain with a standard 100 micron filter.
If not using XTC Primer, apply two coats (1.0 mils/25um DFT each) of XTC allowing at least 8 hours between coats and allow the second coat to dry at least 8 hrs before subjecting surface to any heat. The number of coats of XTC needed depends upon service conditions of equipment.
SPRAY APPLICATION:
FOLLOW ALL CAUTION AND WARNING NOTICES WHEN SPRAYING. ALWAYS WEAR AN AIR SUPPLIED RESPIRATOR: NIOSH/MSHA approved organic vapor particulate respirator.
Spray pressure of 35-45 psi for siphon/pot guns and 25-35psi for gravity/top container guns.
Spray tip size of 1.0-1.5.
Thinning is not generally required but if needed 5%-10% is normally adequate. Use KBS #1 Thinner only which is a slow evaporating solvent. Do not reduce Xtreme Temperature Coating with lacquer thinner. Also remember to clean your spray gun immediately after using Xtreme Temperature Coating.
BRUSH APPLICATION:
FOR BEST RESULTS, use natural bristle or foam/sponge brushes. Apply thin covering coats (1.5-2.0 mils/35-50um wet film thickness). Do not flood surface with coating.
Brush out thoroughly, maintaining a continuous wet edge and uniform appearing paint film. Do not over work brushing while attempting to eliminate brush marks. Whatever brush marks don't flow out during air dry process will flow out during initial heat curing. Do however avoid runs or drips.
Allow first coat to air dry at least 8 hrs before applying recommended second coat. Allow second coat to cure at least 8 hrs before subjecting to temperature curing.
AEROSOL SPRAY APPLICATION:
For best results, apply when spray can and room temperatures are between 60-80° F. Shake aerosol can vigorously for one minute after mixing ball rattles freely & periodically during use to ensure proper mixing and to prevent aerosol spray head from clogging. Repeat shaking frequently during aerosol application.
Hold aerosol can 12-15 inches from surface and apply using steady, even strokes. Apply a minimum of two light coats, avoiding drips & runs. Allow 15-30 minutes drying time between coats. Heavy applications can lead to reduced coating life/adhesion. As with all KBS Products, multiple thin, covering coats is always the best practice.
Clean aerosol spray head immediately after use by turning can upside down and spraying until no more paint appears. If clogging occurs, remove aerosol spray head and clean with a fine wire. Replace carefully, pointing can and spray head away from you.
Allow painted surface to dry a minimum of 8 hours before Temperature Curing.
TEMPERATURE CURING:
After proper dry time, XTC will be dry to the touch and can be handled using care, but resins will not reach full hardness until heated to approximately 350° F for 20-30 minutes. For headers or manifolds, this can be done in an oven, BBQ, OR by mounting back on engine and following the method described next.
For automotive applications, you can also temperature cure by installing and running the engine. After the parts have been installed, start the engine and let it idle until the XTC begins to smoke then immediately shut engine off and let the manifold or header completely cool naturally to room temperature. Repeat and do this process three times total. After the third time, perform a fourth temperature cycling and on the fourth cycle, let the engine run until the XTC smokes and this time let the engine continue to run until the smoke from the XTC dissipates. Once the smoke has completely dissipated, turn the engine off let the surface come back to room temperature naturally. It is important to follow this process to gradually cure the XTC.
NOTE: Coating can emit potentially harmful vapors during the first few heat/cool cycles. Allow for full and proper ventilation during initial heat curing. Avoid excessive heat during this initial "break-in" period, as the resins need to be tempered into the substrate to provide proper adhesion.
THINNING:
XTC can be thinned up to 5% (20 parts paint/1 part thinner). Only thin using KBS #1 Thinner. Note: Use of other thinners may hinder product performance and void product guarantee.
AVOID OVER-APPLICATION:
XTC is NOT forumlated to function well as a thick coating. Always apply XTC in THIN coats and just enough coats for coverage (based upon coarseness of the surface). Never overdo the number of coats of XTC and XTC Primer applied.
DRY TIME:
70°F 50% RH. XTC will air dry tack and thumb print free within 1/2-1 hour. Allow at least 8 hours dry time between coats. Allow at least 8 hour solvent flash off period before heat curing or placing into service.
Optimum film properties require a heat cure of 350°F for 20 minutes. Equipment such as exhaust manifolds headers protected with the XTC in the air-dried state can be reinstalled and then temperature cured.
CLEAN UP:
Thoroughly flush spray equipment and hoses immediately after use with KBS #1 Thinner or lacquer thinner. Dismantle spray equipment and clean parts, brushes or rollers.
STORAGE:
Store in a cool, dry place with temperatures between 50°F and 100°F. Keep container closed when not in use.
QUESTIONS & TIPS:
Q. Do I need to sandblast?
A. No, while a sandblasted surface is ideal for cleaning & providing an ideal anchor pattern or coating adhesion, wire brushing and/or abrasive sanding with 60-80 grit sandpaper will work well also.
Q. How many coats of XTC do I really need?
A. This all depends on the coarseness of the surface profile. The coarser the surface profile, the more thin coats needed. We recommend a minimum of two coats of XTC or one coat of XTC Primer and one coat of XTC (color of your choice). Apply enough thin coats of XTC Primer and XTC to cover the surface adequately. Do not over-apply coats.
Q. Do I need to heat the surface before painting?
A. No, the surface should be at room temperature 50-82°F during application. Do not apply to a hot surface.
Q. Do I need to heat cure after application?
A. Yes, while the surface will dry to the touch within 1/2-1 hour, the coating will not reach it's full cure until it reaches approximately 350°F.
Q. Do I need to temperature cure between coats?
A. No, heat curing between coats is not necessary. In addition, heat curing will not hinder subsequent coats of XTC.
Q. If I temperature cured my piece already, can I apply another coat of XTC?
A. Heat curing will not hinder subsequent coats of XTC.
Q. Is XTC Primer required for adhesion?
A. No, XTC Primer is NOT required for adhesion. XTC will adhere incredibly well to a prepped surface. XTC Primer provides rust protection and hide. XTC Primer should be used when rust protection or hide is desired.
Q. Does XTC Primer have to be coated over with XTC or can XTC Primer be left at the finish coat?
A. XTC Primer can absolutely be left as a finish coat and does NOT have to be coated over.
TECHNICAL DATA:
Characteristics
Jet Black, Cast Iron Grey, Charcoal Metallic, Pure White, Rocket Red, Off-White, Pontiac Metallic Blue, Flame Blue, Clear, Aluminum, Stainless Steel, XTC Primer
Generic Type
Silicone
Color
Black, Grey, Blue, White, Ivory, Red, Silver, and Clear
Temperature Resistance
Continuous
XTC Primer 1200°F
XTC 1500°F
Percent (%) Solids by volume
20-35 (varies by color)
Viscosity
300-450 cps (varies by color)
Dry film thickness per coat
1.0 - 2.0 mils
Wet film thickness per coat
5 - 8 mils
Drying time @ 50% RH
To Touch
To Handle
To Re-coat
To Ship
50°F (10°C) 70°F (21°C)
50 Minutes 25 minutes
1 Hour 30 minutes
10 hours 7 hours
42 hours 20 hours
Full cure @ 350°F
(Heat/Temperature Cure)
30 minutes
Weight per gallon
8.8 - 12.1 lb. (varies by color)
